CampingCooks's avatar
CampingCooks
City Water Intake and Quick Connects- dust cap?
This is my first post, so here goes. On my 2005 R-Vision MaxLite TT, I have the typical city water connection on the outside. I'd like to insert a "quick connect" connector to hook up water quickly. Problem is, if I leave the male end of the connector in the city water connection inlet without a dust cover, it will get dirty from exposure. The standard white rubber dust cover for the city connection by itself does not fit the brass quick connector.
I have looked for a similar dust cap (preferably with a lasso so I don't lose it), and haven't seen any that fit. Does anyone have a solution, or found a dust cap for these quick connect fittings? I have both the brass style and the Melnor brand plastic style fittings. If I can't find a way to protect the quick connector, then it seems pointless to have it on my city water inlet.
I was unable to find any previous posts on this topic.
Thank you for your help!
  • Could you get a female quick connector and attach a pipe cap or something similar to it and make your own protector?
    I do agree that the benefit of having a quick connector does seem to go down considerably if you have to unscrew it from the RV every time you move.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Oct 12, 2025
