  • acker1 wrote:
    rv2go--Thanks for doing the pics. What did I do wrong?
    smkettner--I installed a volt meter up front. I had some spare cat5 cable and used it. I paired the wires off for a better crimp connection. Did the same on the chassis batteries.
    DICK
    What did you do wrong?
    You had URL in the square brackets at the beginning and it should have been a IMG and leave out the = sign. You had IMG in the square brackets at the end and it should have been /IMG instead. Plus, the URL was wrong. I got the below URL from the images posted by rv2go.
    It should look like this only use the square brackets instead of what I use here. It makes no difference if using capitol letters or small ones.
    {img}http://i10.photobucket.com/albums/a133/acker1/Batt2Small.jpg{/img}
    Barney
  • Much better...and safer too I'm thinking.
    Good job there.
  • RoyB's avatar
    RoyB
    Explorer III
    Nice job - Looks alot cleaner now using the bus bars.
  • rv2go--Thanks for doing the pics. What did I do wrong?
    DICK
  • What are the two twisted pairs? I always thought + & - were to be twisted together for a sensor or something.
    Anyway it is looking much better.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
