imq707s's avatar
imq707s
Coating a newer EPDM roof?
I got up on the roof of my “new to me” Crossroads TT and everything looks good. It’s a 2011 TT……should I be thinking about coating the EPDM roof “just because”…..or is that overkill if everything looks good? Do the EPDM roofs ever degrade to the point where they look ok (not cracks or holes), but still let water in?
Thanks for the info!
  • RV roofs are very subjective, do what you think is right. Look closely see if you see any cracks. If you do, then fill them with dicor and keep it with you.
    Its better to be proactive then to chase damage.
    When the rubber material gets old and black, you
    can coat it with one of the coatings made for this.
    I do this on the roof and crawl under to check for
    problems before they become serious. That's just me.
  • Ours is 12 years old I'm thinking of coating it this summer it'seems looking like it could use it.
  • Don't depend on a coating fixing any water leaks. This is a newbie perception, that coating the roof fixes leaks. The integrity of the roof against leaking is done with sealants/tapes that prevent water from entering.
    In another thread, the OP has discovered a rotten floor section near a wall.. The best thing you can do is perform a pressurized interior leak test. That will turn up even a pinhole leak anywhere in your TT. Do a search for "Pressurized leak test".
  • The material warranty on EPDM is pretty good, I think at least a decade. I wouldn't coat the roof because over that period of time, a lot can happen... Replace it when it needs to be replaced instead.
    The sealants are a lot more likely to fail than the EPDM... Especially if you're not diligent about maintaining them.
  • On a 2011 I would not worry about it, just do your normal inspections.
  • My 2004 Crossroads roof is doing just fine. I crawl around up there a couple times a year and take a close look at all the joints, but so far so good.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
