the2sharps
Jul 29, 2017Explorer
Slow progress on this project, but the photo is the water valve control plumbing. It will be attached to the wall of the inside of the wet bay. The water hose from the site pedestal will attach to the female hose coupler at the bottom right with a quick connect. When the normally closed 12v water valve has power, the water flows through it and out the top right through the flex hose which is attached to the motorhome's city water female hose coupler. If the 12v water value fails or for some reason I want to bypass it, I can turn the ball value to the on position. My next step is to mount it in the wet bay and run 12v power to the water valve. I'll control the value with a RF remote control fob on/off switch.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
