myredracer
Aug 06, 2017Explorer II
I wonder what is available for a low flow monitor that you could connect to the solenoid valve to prevent damage from a slow leak?
In view of our toilet valve experience that let water flow into the bowl when the CG pressure got down to around 10 psi, maybe a low pressure shutoff also might be a good idea.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
