- jepalmerExplorerthanks to all
- myredracerExplorer IIHere is a closer pic of the reg. It's low rez, but if you look closely where the alloy body of the regulator is and the brass piece attaches to it, it looks like that would have to be a threaded connection and you can see a little pipe dope showing.
You would need to leave the brass fitting in place on the tube above it that has the holes in as that is where the fuel and air would mix together. It's a case of just removing the alloy body of the regulator and finding a suitable valve or as someone suggested, running full on or off.
The 2nd pic shows the type of control valve you want. This is a Camco item. Looks like you might be able to modify it with the right fittings. The valve in the 3rd pic is made by Magma. I would google "LP propane gas control valve" and see what you can find. Or go to a local BBQ shop and see if they can help.
The easy part is finding a hose with quick connect fittings. This grill appears to be a bit of an oddball for doing a conversion to it. Might be easier and possibly cheaper to find say a Weber Q100 which is straightforward to modify. If you are not familiar with working with propane fittings, get a professional to do it.
- bob_nestorExplorer IIIIf you have a quick connect propane supply on your RV (like my Roadtrek does), then all you need is this hose. Works perfectly fine on my quick connect and screws right into the regulator that accepts the small gas bottles.
- RCMAN46ExplorerIt depends on the control valve setting you use now.
In my case I had always used my grill with control valve full open.
So I just removed the grill fitting from my control valve and adapted to a hose and fitting for the on/off quick connect valve that was on my trailer.
Just remember you will not have any control on the grill but as I stated in my case full flow has worked very well for me.
It may be possible to use the valve on the trailer to reduce the gas flow. I have not tried that as the pressure on my trailer is very low compared to the original grill regulator, I need full flow to get the heat I want from the grill. - Colo_NativeExplorerDo a search with the word Weber Q. I started this and yes you can I went to a propane shop and had all my stuff there also they cut a hose to my specs(any length) and you have to remove the regulator
- diplomatdonExplorerSorry, should have looked at pictures closer. Your regulator is also your control so your LP source has to come from before regulator on RV. Bottom line you cannot double regulate.
- diplomatdonExplorerIt can be done, however your BBQ already has a regulator so your LP source has to be unregulated. You would have to T before regulator on vehicle. The other option is to cut regulator off grill and solder fitting on input to grill. In this method supply to grill would come after source regulator. Hope this helps, have seen it done both ways.
- ChooChooMan74ExplorerI don't think it is possible. You need to find a control valve that is non regulated.
- SkiSmuggsExplorerI know you can get an adapter hose that will connect to a 20 lb tank. I am currently using one for the Mr Buddy Heater. The quick connect will have to be answered by someone else, but you could google something like propane quick connect adapter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
