JiminDenver
May 14, 2016Explorer II
About the only thing I could think of is get a bank of batteries big enough to run a efficient window A/C through the night, then run the generator early to replace the bulk of what was used and then let the solar finish it off.
In a humid environment like that it may only handle the bedroom. The bigger the A/C, the more batteries you will need and longer generator run time.
Using a smaller air conditioner would allow a larger generator like the EU3000is to purr along in eco mode using the least gas and making the littlest noise possible.
Our solar can run a 5000 BTU window A/C through the peak of the day. Our bank can run it over night. The problem is the solar can't replace what was used and run the A/C too, the system isn't big enough. As above I would have to run our big generator with a big converter to get the bank up as fast as possible so the solar can take over and run the A/C again.
Boy am I glad we don't have to do that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
