gbopp
May 14, 2016Explorer
I'm not an expert on the subject but, will the drywall give you enough thermal mass to offset the 300 pounds you will be carrying?
If you're not concerned about the weight, maybe 5/8" drywall would be a better choice.
Radiant barrier insulation needs a 3/4 to 1 inch (furring strips) air space between the insulation and drywall/paneling.
So, if you decide to go with the radiant you will be giving up an inch on each side.
Maybe a better choice would be thicker foam insulation?
Just giving my 2 cents. Good luck with whatever you decide. And, keep us updated on your project.
Enjoy your travels.
Enjoy your travels.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
