roadnurse
May 14, 2016Explorer
rexlion wrote:
Best insulation IMO is sprayed polyurethane foam, about a 6 lb density IIRC. You'd get airtightness at the same time with the insulation factor. Cover with luan or whatever you decide. The downside is, you probably would want to hire out the spray job if you have no experience with the stuff. But once it's done, it's an investment in your comfort.
That may be true, but I think for the size of the area, I'll just do it myself. I did have a large job sprayed once, and it was quite a mess and is difficult to regulate the thickness.
It's factory insulated and covered with Luan now. I'm just going to go over the top of that. I'm certain with the drywall that i'll get air tightness. The radiant barrier should really reflect the heat back out.
It's a crapshoot. I'm just going to take my chances and see what happens. I'm sure that regardless I'll have the most insulated trailer in my neck of the woods :).
I'm going to conduct some tests before and after. Will post photos and test results.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
