colliehauler
May 16, 2016Explorer III
westend wrote:This makes the most sense. You could join Passport America for low cost campgrounds. There is a reason they don't use sheet rock in a moving RV. Would go with the above suggestions.
I'd suggest to use expanded foam board on the walls and ceiling. Incorporate a vapor barrier. I wouldn't have drywall in a trailer, it makes no sense when better alternatives are available and cost less. You could pull the factory paneling and reinstall with longer screws.
A 5000 BTU A/C window unit will cool that trailer to meat-hanging temps. How you power it will be up to you. I'd search for a cheap campsite with 120 available or try to plug into someones exterior receptacle with an agreement to pay for power.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
