roadnurse
May 21, 2016Explorer
For what it's worth, I'm going to drywall the walls, but not the ceiling. I can then get a nice finish on the walls, and I can fix it easily if I need to. worst case scenario is that I cove it with luan.
I bought a 400 watt solar kit from Renogy and a quality 1000 watt inverter. Now for a bank of batteries and a battery charger. I'm going to buy one of the new fridgidaire 5000 watt ac's with an eer of 12.2, only uses a hair under 500 watts i think. When it's done, I'll have $7000 in my trailer, $2500 of that in the solar/batteries/electronics. The remaining and rather large issue is how much I can quiet the compressor.
I'm not shooting for so quiet you can't hear it running. I'm shooting for simply a very relatively quiet AC and generator. I don't care if people who look closely at it know it's a camper. This is about going anywhere and towing a compact, easy load instead of a traditional 5th wheel type of rv.
I'm simply going to look for inexpensive rv parks on assignments and then be able to boondock in nature on my days off. Should I need to do the Walmart thing while on the road, that's fine as well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
