TUCQUALA's avatar
TUCQUALA
Dinette Storage Drawers
Never liked taking the cushions off of the dinette seats to retrieve stuff inside that can't be reached from the door area. Consequently, probably only used 50-60% of the area under the seats.
Built a couple of boxes that slide on nylon guides just wide enough to go through the door. One side is full length, other aboot 6" shorter due to electrical area with cover over it. Opposite end has wheels to roll the load out.
Probably still will use less than full capacity, since the drawers are only as wide as doors allow. Didn't want to open up the door area and find or build new doors, nor did I want to put slides in due to mounting concerns with slide out floor AND cost!!!!
Going to put a couple of 1X2's in next to the seat frames to guide the wheels when going in and out!!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
