zell66's avatar
zell66
DIY Awning lights
I have a 2012 Sandpiper 365SAQ and I want to install a LED strip on my awning tube. Is there a way to add a strip and wire it into the power awning?
  • Consider installing it tucked up under the awning near the sidewall. That way it's protected, but can be used even when the awning is rolled up. I did that with one having a remote, and mounted the controller in the porch light. I use the porch light switch to turn it on/off, and can also use the remote to control color/brightness (it's an RGBW strip).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
