Dbrown1's avatar
Dbrown1
Duo-Therm 2003 15000 btu needs replacement.
Help!, my 15000 Duo-Therm roof top unit went out on my 2003 RV. Can I get a direct replacement without changing the inside part?
    My past 2003 Fleetwood Class C had the same AC. It was ducked inside. I just replaced the roof-top unit. I worked fine after that.
  • A quick google search says units are available. Your question is too vague. e.g. why don't you want to change the inside part? No access? Are there two a/cs ? Might be the cable connecting them.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
