12thgenusa
May 04, 2011Explorer
DD716TED wrote:
I love this mod and have came across the electronic module in a close out bin for $8... where can I find the 3 electrodes needed to do the install since my stove is currently a match light unit? It is a Suburban so do I need longer electrodes or what? Not concerned with oven at present...
You will need to add electrodes. I think these could be made to work. You might have to make a small angle bracket to mount next to each burner and experiment with air gap for optimum spark.
This place also has igniter wire that you will probably need. Or you might be able to make your own wiring to ensure you get the right type/size connectors for the module and electrodes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
