12thgenusa
May 10, 2011Explorer
The igniter is only secured by the plastic nut, but everything seems very well held in place. I used a couple of small plastic "upholstery plugs" to cover the two holes, which you can see in the third and fifth pictures. I think you can get them at an auto parts store. A round or square sheet metal plate would also work on either the inside or outside. The igniter and nut would hold it in place on whichever side you installed it. I think there is also room to install short screws with nuts to plug the holes. The battery cover/button comes right to the edge of the holes, so you might have to shave the edge of the plastic buttons or screw heads.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
