Duramax1
May 12, 2011Explorer
DD716TED wrote:
Since my Suburban Stove had no previous ignitors, I have to install 3 of them... I have made sheet metal brackets and mounted the insulator/spark devices to them... QUESTION... will mounting these brackets directly under each burner to the metal bottom of the stove panel with short 1/2" sheet metal screws hurt anything?... I am sure there is a considerable gap / insulation between the bottom of the stove and the oven liner but I thought I would ask first..
My stove does not have any ignitors either. How are you going to make the hole in the front of the stove to accommodate the ignitor mechanism?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
