bpounds
May 17, 2011Nomad
The wire I used has a teflon inner sheath, and a woven cloth outer insulated cover. I'm sure it is good for 500° without any other cover. So I think you should just use wire that is made for the application.
For example, you can get a piece here:
http://www.appliancefactoryparts.com/gasgrillparts/bbqparts/igniter-wire.html
And for a good selection of igniter electrodes, check here:
http://www.appliancefactoryparts.com/gasgrillparts/bbqparts/igniter-electrodes.html
Most of the electrodes come with a wire that is already properly insulated.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
