Dutch_12078
May 18, 2011Explorer III
Duramax1 wrote:
This information is for those of you with a Magic Chef stove that does not have any ignitors.
Last year I investigated doing this project and, like others above have noted, discovered that the four wire ignition kit from Home Depot is too high to fit in the stove.
This year I discovered that WalMart has a three wire ignitor kit which sells for $15.97 in Canada which will fit into the stove. I used a 25mm hole saw kit to cut the circular hole in the front stove panel.
Can you post a photo showing how you mounted the ignitors at the burners?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
