tvman44
May 19, 2011Explorer
You did remove the top to expose the igniter and wiring?
I just a few minutes ago did mine using a coat hanger down the right side hole and it was a piece of cake. Don't give up. Try again & again.
ralphnjoann wrote:
I thought the easy part would be routing the wire from the oven igniter to the control. Wrong! I've tried a coat hanger, a flat piece of plumbers strapping, and the wire itself in both the right and left openings behind the top burners going from top to bottom and bottom to top and I can't get it to go through. What am I missing? Thanks. Note: The stove is an Attwood.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
