bpounds
May 19, 2011Nomad
ralphnjoann wrote:
Is it simply a matter of just keep trying? If so, I will. Thank you.
Yes, keep trying. I think you want to go up from the bottom right corner, to the top right corner. Same route as the gas supply and thermocouple tube. In the top right corner I can see all the way back to the wall of the trailer. I pushed a piece of MIG welding wire up from the bottom, wiggled it around a bit, and saw it right away in the back corner up top.
Sometimes it helps to shine a flashlight up one hole, and how it shines through can help you figure out where the path is clear.
Worst case scenario, you could pull the range out of the cabinet with just a few screws.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
