Dutch_12078
May 19, 2011Explorer III
Duramax1 wrote:Dutch_12078 wrote:Duramax1 wrote:
This year I discovered that WalMart has a three wire ignitor kit which sells for $15.97 in Canada which will fit into the stove. I used a 25mm hole saw kit to cut the circular hole in the front stove panel.
Can you post a photo showing how you mounted the ignitors at the burners?
I will take a picture the next time I am at the RV.
Basically what I did was make a bracket which I affixed to the base of the stove by removing the screw that holds the burner in place. I shaped the bracket so that the igniter base was level with the bottom of the burner and then I bent the igniter wire so that it would fire at the opening where the gas comes out of the burnner.
The shaping of the bracket does have to be rather exact otherwise the stove top cover, when lowered, will close on top of and interfere with the ignitor.
Ok, thanks, that would great... The kit I have from Walmart has one really short igniter and two long ones that can be shaped as needed. It's the short one I'm wondering about.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
