AnEv942
Mar 14, 2014Nomad
Myredracer- yes either will work. As long as the spark is in the gas flow path. Most, where you see 'inside' the burner are using factory ignitor. Thats what I did, unplugged stove top ignitors from manual striker and plugged into the new one.
Which is what I believe 12thgenusa (OP) did, then later installed externally as noted here.http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24521274/gotomsg/27034982.cfm#27034982.
Been a while scince I had my burners out-Im unsure you can seperate to install inside? Does your stove top have the manual striker?
Mark
Mark
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
