RTBabich
Dec 27, 2014Explorer
Just finished the conversion on our stove, works great! For those who don't need igniter wires the BBQ factory 03350 Spark Generator is available at Amazon for $5.55. It looks very similar (if not identical) to the Char-Broil 4586094P unit at Home Depot for $21.99. The module is 2 5/8" W x 2" H x 1 1/2" D with 6 contact ports. Our 2008 Magic Chef 3 burner stove has a single igniter in the center distribution point for the 3 burners. The original igniter wire used a round connector which when squeezed flat fits snugly on the contact. I put blobs of silicone in the unused contact ports. When the spark generator is triggered you can see there are 3 paired contacts. I used the appropriate paired contact to run a return wire to a case screw to complete the circuit since I only have 1 igniter. We have a convection/microwave - no propane oven, so only one igniter total. The spark generator needs a 7/8" hole so I screwed a block of wood behind the panel using the original screws holes, measured where the center of the button would be and used a 7/8" hole saw to cut the new hole.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
