sgfrye wrote:
yankee camper wrote:
I would definitely use the prime. Did the side seams on my 5th. wheel and portions of my roof and the eternabond started pulling away within a year. Yes it was properly prepped prior to being applied. I re-did it but this time used the primer and it is still 100% good 2 years later. Pay a little more and only do it once cause it's a PITA to remove it even if it's pulling up on it's own. Just my 2 cents.
Thank you for that info. Thats what i was thinking also.
Make sure you use a roller when applying the Eternabond. I prefer a steel roller, some like a wood roller.
