- Edd505Explorer
justALnow wrote:
I'm trying to build an extended run fuel system for my Champion Digital Hybrid (Model #100302), but can't find the replacement gas cap.
Anyone have any links to one?
Contact Champion they have part to repair tier stuff, my manual even gives the part numbers. - justALnowExplorer
justALnow wrote:
jjrbus wrote:
Was curious after posting and took a peak.
https://www.pinellaspowerproducts.com/product-category/products-for-other-brand-generators/products-for-champion-3100-3400/
Thanks for the link ... Mine is the Champion digital Hybrid 4000/3500 and uses a different cap than the 3400/3100. Might have to drill and tap the existing cap ...
That's what I ended up doing. The cap is passively vented, so I had to run a bead of silicone around the inner lip so it would create a suction to pull gas from the auxiliary tank. Fired it up and ran it a couple of hours... enough to determine that it was successfully pulling gas from the Aux tank and not just running on what was in the generator tank. - justALnowExplorer
Thanks for the link ... Mine is the Champion digital Hybrid 4000/3500 and uses a different cap than the 3400/3100. Might have to drill and tap the existing cap ... - jjrbusExplorerWas curious after posting and took a peak.
https://www.pinellaspowerproducts.com/product-category/products-for-other-brand-generators/products-for-champion-3100-3400/ - jjrbusExplorerThis man is a gold mine of info, possibly you will find some info there to help. Contact him and if he sees a market he may make one up.
https://www.pinellaspowerproducts.com/ - MrWizardModeratorPulse pump,.vacuum operated, kit comes with spacer with hose nipple on it, spacer goes between carburetor and intake manifold, manifold vacuum, drives the pump,
- BobboExplorer III
agesilaus wrote:
Where does the power come from for a pump?
From the generator, maybe? It has a 120v and a 12v outlet. - justALnowExplorer
MrWizard wrote:
Nobody makes a correct replacement cap that I'm aware of
How ever SuperGen used to sell a kit for champion generators, came with a vacuum operate pump,, connecting hoses, nipple etc,
A diy install, I put one on a 3500
CAT5 inverter generator, worked fine as long as both were on the same level ground, my champ was on a sliding compartment tray/drawer so I would put the extension tank/can on a snack table or chair next to the genny, sorry don't have a link, using my phone not my laptop
Thanks! Kind of what I'm finding...
I built a system for my Honda 2200 and it works great ... Parts were readily available on line! - agesilausExplorer IIIWhere does the power come from for a pump?
- SidecarFlipExplorer IIIDrill and tap the existing cap for a nylon threaded fitting, add a hose and another gas can but keep the bottom of the can higher than the genny. Conversely, you could add a pulse fuel pump and run from a marine porta tank.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
