Hornnumb2ExplorerNov 09, 2021exterior trim sealingI am redoing the filon on the rear wall, when putting corner moulding back up. Do I use butyl or caulk?
2 RepliesReplies sorted by NewestRollandBExplorerNov 10, 2021You might want to check out this video, Ray does a good job documenting the steps he told to seal up the corners after doing some rot repair. https://youtu.be/PO8EvZ4AAp8jdc1Explorer IINov 09, 2021Butyl. The tape is easiest.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
Related ContentExterior plastic trim crackedSealing exterior joints ?Quick connect exterior shower hose doesn't connect.Sealing exteriorNeed exterior trim piece
