CA_Traveler
Oct 23, 2018Explorer III
garyemunson wrote:Thanks for the fan link. Since the refer design is for hot air to rise I would want the fans to exhaust at the top.
I ended up with the fans intaking at the top and blowing the hot air out the bottom. I can reverse this if I find it's not working next summer.
Fans I used..
https://www.ebay.com/itm/2x-10-inch-Universal-Slim-Fan-Push-Pull-Electric-Radiator-Cooling-12V-Mount-Kit/151521113218?epid=502641911&hash=item23475cb482:g:Ho0AAOSwuMFUlG0W:rk:7:pf:0&vxp=mtr
I plan to add snap disk to automatically run the fans when the temperature rises. Maybe on at 130F and off at 110F. And a switch inside.
Since the refer uses 12V it should be easy to to connect the fans.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
