2012Coleman
Oct 23, 2018Explorer II
Old-Biscuit wrote:
DRAFT......that is the natural air flow due to convection
The airflow (DRAFT) needs to be cooler air PULLED in thru lower vent and then exhausted out the top vent
This will PULL air up thru absorber tubes and then across condenser fins.
Nice idea on extra fans.....bit over kill on the amp draw....but YOU have it WRONG with the airflow.
Bottom to top NOT top trying to push air downward.
Sounds to me like this is what he is doing.
OP wrote:
I decided to install more robust fans that will exhaust directly out of the rear compartment top vent.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
