garyemunson's avatar
garyemunson
Explorer II
Oct 23, 2018
External fans for Norcold fridge
Gary Munson
10 hrs
In September we took a trip from Nevada to Florida. For most of the ride we encountered unseasonably hot weather. Kept having the problem of the freezer and fridge running warm (10 degrees freezer, 45 fridge). At night, with cooler air, the freezer would go to 0 and 35 for the fridge. Examining things, it became obvious that while driving, there just was not enough air circulating through the rear of the fridge area. I'd previously replaced the sensor for the original fans but the little computer size things just were not doing the job. And, yes, the recommended shrouding was in place. I decided to install more robust fans that will exhaust directly out of the rear compartment top vent. I found these on eBay for about $25. They are small automotive radiator fans. I found wiring them in series cut the speed down and made them very quiet and also reduced current draw to less than 4 amps. They still move a LOT of air. I used flat aluminum stock from Home Depot to make the support brackets. As the RV wall is plywood over foam, I Liquid Nailed a couple strips of 3/4" wood to the inside of the wall to provide something solid to screw the rails to. I'll probably have to wait until next summer to see how this will work but I'm optimistic!
  • nice but your amp draw is high, get some computer fans, two of them hardly draw a amp.
  • garyemunson wrote:
    I ended up with the fans intaking at the top and blowing the hot air out the bottom. I can reverse this if I find it's not working next summer.
    Fans I used..
    https://www.ebay.com/itm/2x-10-inch-Universal-Slim-Fan-Push-Pull-Electric-Radiator-Cooling-12V-Mount-Kit/151521113218?epid=502641911&hash=item23475cb482:g:Ho0AAOSwuMFUlG0W:rk:7:pf:0&vxp=mtr
    Thanks for the fan link. Since the refer design is for hot air to rise I would want the fans to exhaust at the top.
    I plan to add snap disk to automatically run the fans when the temperature rises. Maybe on at 130F and off at 110F. And a switch inside.
    Since the refer uses 12V it should be easy to to connect the fans.
  • I really need to do something similar. My hurdle will be where to get power. Thanks for the link - I'll look into these fans.
    Can you post the dimensions of the frame?
  • I ended up with the fans intaking at the top and blowing the hot air out the bottom. I can reverse this if I find it's not working next summer.
    Fans I used..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
