- Yosemite_Sam1Explorer
jdc1 wrote:
Yosemite Sam1 wrote:
jdc1 wrote:
ppine wrote:
How long are you going out there for? Water weighs around 7.2 pounds per gallon. Train your crew to use less water as an alternative.
When I had my 37'motorhome, the 100 gallons would last just over 3 days, comfortably. 40 gallons is only good enough for 1-1/2 days, at most.
We must not be showering often enough to more than once a day.:E
We have a 52 gal capacity and we never ran out of water in our 4-day camping cycles.
In fact, I was about to buy an auxiliary water-bladder but never came to doing it because we don't run out of water anyways.
The wife is a retired nurse....she washes her hands when the wind blows.
I bet she sings happy birthday, happy birthday to you... when washing her hands.
And your biggest household expense is hand sanitizer.:D - ppineExplorer IIOkay water weighs 8.3 pounds per gallon, more than diesel.
For boondocking, I think it makes sense to teach your crew to conserve water. The example of 100 gallons per day is out of control.
We can stay for a week with a 35 gallon tank, and 5 gallons of drinking water.
Backpacking teaches people to get by on a gallon a day per person.
I like solar showers. I usually heat water on the stove instead of firing up the 5 gallon hw heater. Do whatever you want, but realize what is possible. - dieseltruckdrivExplorer II
rrupert wrote:
Water weighs 8.3 pounds/gallon.
Yep, its diesel that weighs 7.2 lbs/gallon. - jdc1Explorer II
The wife is a retired nurse....she washes her hands when the wind blows. - LwiddisExplorer II“When I had my 37'motorhome, the 100 gallons would last just over 3 days, comfortably. 40 gallons is only good enough for 1-1/2 days, at most.”
How many people? And the size or type of RV doesn’t increase water use. - LwiddisExplorer II“The one panel that Open Range sells, think it is a Furrion and think it is only 50 amp.“
End your debate and do some reading on solar. - LwiddisExplorer II“Water weighs around 7.2 pounds per gallon” Try 8.34 pounds per gallon.
In fact, I was about to buy an auxiliary water-bladder but never came to doing it because we don't run out of water anyways. - jdc1Explorer II
When I had my 37'motorhome, the 100 gallons would last just over 3 days, comfortably. 40 gallons is only good enough for 1-1/2 days, at most. - rrupertExplorer
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
