AnEv942
Apr 21, 2018Nomad
New ladder and adding basement storage
Something Ive always wanted, folding ladder, but could never justify cost, storing, just no real practical need.
However recently installed WiFi then cell antennas and realized if I had an auxiliary ladder I wouldn't need to get on
roof to raise. Margaret agreed so picked a GP Logistics SLD-D7 Double Sided Folding Ladder - 7' ladder.
These fold like a standard step ladder but also fold at mid of rungs collapsing to 3 1/4" X 4 1/4" X 7'.
To mount I placed on bumper against campers ladder.
Made a small box to capture bottom of ladder rails.
Bent an aluminum bar to secure with extra Torklift lock. Also using ratchet to snug against rattling.
Surprisingly worked out well, functional, easy to retrieve and replace. But...
Other than appearance, couple of other things I don't like. Primarily its location, living out side exposed to the
elements, road wash. Second is it will need to be removed to access the generator, or retrieve the scooter ramp.
It totally blocks the porch light, and we can no longer carry the factory flip over step. Its used to access main ladder.
Functional, but day to day I think it will be a pain.
Looking at options decided if I rearranged the stuff in basement tray it might live in there. Wouldn't be as
convenient, but then I noted the area between the tray and generator, again. Ive always wondered about the
space.
Probably 2/3rds of our campers basement area is unused, inaccessible.
From an older thread-discussion was about utilizing some of this space with marine type floor deck lid.
Never persued but now looking again..
All I would need is door large enough for ladder (red) and pretty confident the space between tray and
generator is empty (green). Though not enough to cut wall and find out it isn't.
Then it occurred to me, Removing the tray I could cut an access hole thru divider wall, poke a camera inside
and see to verify.
I hate jig saws. Cutting blind, blade took off, Ill clean this up later, cut another piece of ply
with a hole to reinforce.
Access hole...
Max length due to captcha- continued
