Blutoyz's avatar
Blutoyz
Flex seal paint on roof edge
Hey All,
My rig had some water leaks sealed by the RV shop that I bought it from and the interior is dry. The sealant is not very attractive along the top edge and can be seen if you look closely.
My question is:
Could that white "Flex-Seal" rubber paint they sell work to clean that up? I thought that is would give it a uniform edge up top and worst case help prevent an future leaks. They do make a white in brush on I believe, I was thinking spray would be a PITA.
What say you???
  • I wouldn't use Flex Seal. Many say it peels off.
    What did the RV shop use to seal the roof that is so unattractive?
    What color is it?
    I also recommend Eternabond along the edges and all seams.
  • Most RVers won't recommend Flex Seal. You might consider Eternabond - looks decent and great for preventing leaks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
