pnordan
Nov 27, 2012Explorer
Floor heat
ha anyone here ever put electric heat blankets under their rv flooring? Supposedly, it is only 1/8 thick so if you were replacing carpet with Allure it should fit.
Boarhog wrote:Radiant electric is the most inefficient method of heating a structure, efficiency being measured on $$$/interior temperature.
Actually I am planning to place some electric radiant floor heating in the hall way of my coach. My research indicates that it is quite efficient, I was thinking of first trying a somewhat temporary installation over the carpet and cover it with a runner. You can adjust your thermostat low at first to see if there are any problems.
But first I'm going to try it out on my dog's outdoor residence. I'll let you know how it goes.
downhome wrote:
Not a good idea.
If you have the capability instead install a heated floor element under the flooring.
