compint
Jun 03, 2015Explorer
Hello,
I have a kitchen slide out also that has rollers across the linoleum. If I use 7MM or 8MM laminate, will this affect the rolling across the area where the linoleum is now?
Has anyone replaced with hardwood and had to "lift" the rollers up onto the linoleum? How would this work?
Thanks in advance.
Thanks in advance.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
