mikebreeze
Feb 13, 2015Explorer
You will probably need an electronic flasher for your turn signals as LED's will flash very fast with a conventional turn signal flasher. This is available at auto parts store. As for the LED's I had to experiment. Some things I ordered worked great. Some I had to try again. I have converted all of my lights to LED's except:
Interior Dome Light- It is attached to a fader and LED's won't work on a fader circuit.
Front Turn Signals- Just haven't gotten around to replacing them yet.
Headlights- I have to research what is the best solution for them as far as brightness and energy savings go.
They do make your battery last longer and they are cooler.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
