- jjrbusExplorer
old guy wrote:
I have used the grease zerk fittings for years and years and all my TT's and never had a stuck gate
Zerks are the only way I will go, never had a problem with them! - ScottGNomadA weekly Mexican food meal and ours is kept working smooth.
- old_guyExplorerI have used the grease zerk fittings for years and years and all my TT's and never had a stuck gate
- LynnmorExplorer IIWhen I replaced my cable operated valves, I ran small diameter tubing to the same place shown in the video. I used an old valve to test the silicone lubricant and it worked for a very short time, then it swelled the shaft seal making the valve tight and useless. Then I tried the same test on another valve using motor oil and that worked.
- Ron3rdExplorer IIII've seen similar posts here where a zerk fitting is installed and you pump the valve with grease. Your post looks like an easier option.
- 2oldmanExplorer IIGreat idea. thanks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
