rockwind1's avatar
rockwind1
Explorer II
Apr 30, 2014
hard start capacitor supco spp6E or spp6 ac unit revisited
I am going to do this mod on my ac's and i have read a ton of different forum discussions. but most are from 2-5 years ago and there are still some unanswered questions. hoping someone on here has gone down this path before and can help
most people say use the spp6E but when i look it up, there are 3 different choices, all with different uf ratings, i bought the 1/2 hp to 3 hp one,,,88uf-106uf,
however, why not buy the size up with 130uf-156ufs? is this too much for the unit?
i have 2 units, one a 15k and the other a 13,500
also, the volt range on the spp6E is from 170 to 277, obviously my ac unit is 120 volts. does this make a difference?
they also now offer a spp6TD with a break on delay built into it, which seems nice.
the smaller spp6 seems to be rated from 120 to 288 vac.
which one is the question?
are rv air conditions
my ac's draw about 24amps and 21 amps for the start, then drop down to 8-11 amps running in 75 degree weather.
what sort of starting amp drop will i see?
thanks for looking at my post and for any help, kevin
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
