- pauldubExplorerIs the jack just a 1/4" headphone jack? If it is, search for surface mount headphone jack. Aircraft Spruce has some surface mount housings.
- northshoreExplorerhttp://rvdoctorgeorge.com/
You could check with RV DR George, he is in Sacramento CA
They have tons of stuff and a call to them or an email might produce what you are looking for.
I have been there a few times, and have contacted them looking for older RV items, and they have always tried to help. - ajridingExplorer IIBontragers asked for a pic, they are looking I think, but it has been several days so i do not expect a reply from them.
I AM STILL LOOKING>>>> - BarneySNomadYou might give Bontragers RV Supply a try. They have about the largest supply of surplus RV stuff I have ever seen. You can wander their various warehouse barns all day and still not see everything.
They are located southern Michigan not far from Elkhart, IN. where most RVs are made.
Barney - ajridingExplorer IIThanks for asking the RV shop. I have a friend in CA that is near those new-old-stock places, I will see if he can stop by. In GA we have few RV resorces for salvage.
- mgirardoExplorerPerhaps try a RV salvage yard. Both our Jayco Pop-up and our Rockwood Hybrid TT used those type of 12 volt connectors for bunk-end fans/lights. I'm sure there is a camper or 2 in a RV salvage yard somewhere that have some.
-Michael - whiteeye42Exploreri did some asking at a couple of rv supply houses and showed them the picture and was told that they were no longer made and they checked with a few of their suppliers to see if they knew of any and the suppliers said they could not locate any.
- FishermanExplorerWell I tried using google images search and came up with nothing.
- DrewEExplorer IIIIf you have or know someone with a 3D printer, this is the sort of thing that would not be too hard to design and print out a pretty close fascimilie of. If a perfectly smooth surface finish is required, there is some additional effort in finishing (sanding/painting) since 3D printers leave visible little layer lines due to how they build things up.
- ajridingExplorer III guess I should have explained that I know how to do an internet search and have done that and have seen 1,000's
I have not found the one pictured.
Thanks for typing in DC OUTLETS in any search engine and sharing the results, but this does not turn up the desired results.
I have also searched a few auto parts store sites, a few RV parts sites and ebay...
I figure even if it is discontinued that there is still some stock out there.
If someone happens to know of a place to get this, or very similar (bob's link is close) let me know, thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
