wiredgeorge's avatar
wiredgeorge
Home Depot Allure vinyl floor
Have been getting ready to pull the trigger on some Home Depot Allure flooring to replace old carpet. The flooring has stick-strips on the edge and looks very easy to install... BUT
When I went to one of the product pages and looked at customer questions, when asking if the Allure can be installed in an RV, a rep from Halstead Product (guess they are the manufacturers?) answers:
"Thank you for your question. No, because this is recommended for climate controlled ares with running heat and air year round between 65-85 degrees."
Has anyone who has installed Allure seen temp related issues? Since quite a few have installed this stuff, not sure why they are fussy about temps. One person opined in an "answer" about RV use that the cold could cause the tiles to become brittle and crack and the heat could cause the adhesive on the strips that join the tiles to let go... Any help would be appreciated. Thanks!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 14, 2026
