2Macs's avatar
2Macs
Homemade Wheel Chocks
Back in 2004, I made a clamping chock out of a 4x4 and threaded rod that worked well for me through the years. During the winter of 2013, it was stolen off of my TT while in storage.
I have made two new clamping chocks like the old one and I thought I would share it. My materials were purchased at Lowes. Some material I had lying around the house.
Materials purchased:
(1) 4X4X8 treated fence post $7.57 ea (enough for 4)
(2) 5/8"X24" threaded rod $3.93 ea (3/8" or 1/2" could be used)
(6) 5/8" galvanized washers $.43 ea
(4) 5/8" galvanized nuts $.27 ea (Only used 2)
(2) 5/8" stop nuts (nylon insert) $.44 ea
(2) 5/8" hex nuts $.17 ea
Total purchase was $19.83 plus tax.
I cut (4) 12" blocks from the post with opposing 45 degree cuts. This is based on the axle spread of 31 1/2" O. C. of my TT. You may want to increase or decrease this based on the axle spread you have. You may want to adjust the degree of opposing cut also. I used 45 degrees because it is convenient.
A 3/4" hole was drilled through the center of each block.
The threaded rod is inserted through the non-moving block and secured on the bottom with washer/stop nut and a washer/galvanized nut on the top.
The top moving block is inserted through the hole and secured with a washer and hex nut welded to a piece of 1/8" X 1 1/4" strap steel I had laying around to turn the nut for tightening the chock. (I tried welding a galvanized nut to the strap steel and found it does not work well. Also, the quality of my welding is terrible, but it works. The padding on the tightening nut is a piece of 1/2" pipe insulation and black tape. The strap steel had a 3/4" hole
pre-drilled in it and the nut welded over the top of it. If you do not have a capability of welding, try your local high school vocational welding class to make the turnbuckle nut.)
The finished chocks provide a significant amount of surface area against the tires and pressure can be applied as necessary to insure your RV stays where it was put. I am including pics of the final result.
  • How about using a pipe clamp rather than threaded rod?
    Slide it until nearly tight and then turn the handle to complete the tightening.
    That is exactly what I have been planning on trying.
  • Exact mod that I just did last week. I had the pipe clamps, old black pipe, and 4 foot leftover section of 4x4 laying around. Didn't cost me anything new.
  • I made a pair of pipe clamp wheel chocks and have used them for years. They work great!
  • I made a set using bolt, washers and nuts, but I have noticed that although they do keep the trailer from rolling, they will still allow the wheels to rock forward/backward slightly. With a family of 5 sleeping inside, I need to stop as much movement as possible to keep us from waking each other up anytime someone rolls over in bed!
    I wonder if two bolts spaced out as close to the tires as possible would do it?
    need to take more weight off the suspension if the tires are moving that much and easily.
    Do what you want with chocks, but the trailer is still sitting on rubber donuts and flexible springs. Adding another pair of jacks, just in front of the tires, will eliminate much of that flex.
  • I also use pipe clamps. I got 2 short threaded iron pipes from Lowes. Several large washers and a cap end. All in the plumbing section. Made the wood blocks,drilled a 3/4 hole and put it all together. Had them for 11 years now. The cap end gets rid of the adjustable pipe clamp and you only use the handle end which threads onto the pipe..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
