What has not been mentioned
Batteries are at the lowest in the morning, so is the sun
By the time the sun is in position to give max power, the batteries have been accepting a charge for at least 4 hours, and are no longer needing what they might have accepted IF full rate had been available hours earlier
As they charge internal resistance goes up, and it takes a higher voltage just to maintain that 8 amps, into the batteries
On a day with moving clouds, connect inverter turn tv and DVD, watch a movie, then go check the meter, you will see much higher Peak outputs recorded, and higher avg output reading
