Jpatrickc
May 16, 2016Explorer
I believe 1971duster340 is correct. The glass lens has some tabs that twist into the metal frame. Pop the whole frame and lens down so you can hold the metal frame from turning and the turn the glass counter clockwise about a quarter turn. If it is the same lens as I have you will break off the tabs if you try to pry the lens off.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
