2001400ex
May 16, 2016Explorer
Lazy D wrote:
Looks a lot like mine. That lens should just pull out. It is real tight. Held in with a flat spring type retainer.
Mine are a G4 bulb.
Something like these might work for you.
http://www.amazon.com/dp/B00W1038SS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=36HHYDB8CCEAG&coliid=IY3QGR26E8B3C&psc=1
OK I got in. Just twisted it counter clockwise while holding the base. It was tight but eventually came off. Here's the pics. Are those the correct bulbs? I want something in the range of 5k rather than 3k tho. Any recommendations?
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
Please see sticky at the top of the forum about posting pictures.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
