I'm not the sharpest tool in the shed. I have a 2013 shockwave toy hauler from forest river. I want to replace my bulbs with LED bulbs to reduce the power draw. But I can't get into the bulbs. I pull ...
I found these at Lowes. I replaced my G4 bulbs in the bathroom and there is a lot less heat and amp draw. The downside is I had to open up the reflector where the bulb plugs into. The base on these are wider than the incandescent it replaces.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
