mighty7sd's avatar
mighty7sd
How to mount to thin walls?
What do most folks here do when mounting something to their camper walls? Toilet paper holder, towel bar, pictures, etc? I feel like the screws supplied with most of these things would just go right through the wall. I don't actually even know what the thickness is on the interior and exterior "walls." Does not feel very thick. Double sided tape? velcro? Smalls screws?
  • I tried rivets, but they just pulled right through the thin wall, I think they are really intended for sheet metal. I finally found the smallest toggle bolt I could and it works great! http://a.co/h0EzL2R
    At least in my bottom of the line RV there is no foam in the interior walls, so no issues.
    Did you use an RV Oscar rivet tho? An ordinary "pop" rivet will not work unless you can get behind the wall surface and put a washer on the rivet first. An Oscar rivet has high holding strength and you normally shouldn't be able to pull one out through 1/8" luan plywood.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
