K_Charles
Jul 10, 2016Explorer
above post may be true for most slides. It if the legs have springs they my only be single sided cylinders and the pump pumps the oil thru the valve to the cylinder and the valve closes. When you want them to go up, the valve opens and the spring pushes the oil back to the tank without the pump.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
