opnspaces
May 22, 2014Navigator III
It was pretty easy to do. I bought everything at Home Depot including the clamps to hold the pipe down.
I also learned to shut off the valve and drain the pressure out of the hose before trying to disconnect the quick release. If you don't it will spray a lot of water into the storage area.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 15, 2026
