Another solution is that Southco makes a cabinet latch with a built-in microswitch that they call the "grabber". I just installed one on our pantry door for LED lighting I installed inside. These catches come in 3, 5 & 10 lb. rating - the 10 lb is what I bought and is too strong - 5 lbs would be better.
Southco also makes them without a microswitch and are an excellent upgrade for the standard flimsy roller catches that are commonplace in RVs (which don't always work that well). These latches, less microswitch, are also available from RV Designer and JR Products.
