ewarnerusa's avatar
Jan 26, 2015
I want to install a 12V digital volt meter
I wanted to install a digital LCD volt meter with LED backlight display that I bought off amazon. I'm familiar and comfortable with 12V electrical and I have decided to just tie into a 12V connection from behind the existing control center (where the tank/battery gauges are, water pump switch, water heater switch, etc.). I'm going to mount the volt meter above the control center. While the LED backlight would draw very little juice, I figured I'd want a way to switch it off to avoid any unnecessary parasitic loads. My plan is to wire up a switch that will turn the volt meter display on and off. I snooped around with my multimeter and there are many different wires carrying the 12V signal to choose from. My plan was to pick a favorite and tie the switch into it, then hook the meter to the switch.
Anyone have any comments or suggestions for my idea? Thanks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,398 PostsLatest Activity: Dec 28, 2025
